[Qgis-developer] [qgis webclient] hide layer in menu
Andreas Neumann
a.neumann at carto.net
Wed Aug 28 04:29:03 PDT 2013
Hi Otto,
If you provide the "visibleLayers" property in the URL, it will be
used. If you do not provide this property it will use the visibility
setting from the QGIS project. You need to set
var useGetProjectSettings = true;
to be able to use the visibility from the QGIS project. It does not
work with GetCapabilities.
Andreas
On Wed, 28 Aug 2013 12:58:47 +0200, Otto Dassau wrote:
> Hi,
> if I want to hide the visibility of a layer in the qgis-weblient, so
> it is
> not initially visible when I open the webclient in the browser but it
> should still be possible to show the layer, if I want.
> It seems that qgis webclient doesn't understand, if I hide the layer
> from
> visibility in the QGIS project.
> Is there a trick to achieve this?
> Thanks
> Otto
> Qgis-developer mailing list
