[Qgis-developer] [qgis webclient] hide layer in menu
Otto Dassau
dassau at gbd-consult.de
Wed Aug 28 07:26:16 PDT 2013
thanks Andreas, that was it...
Regards
Otto
Am Wed, 28 Aug 2013 13:29:03 +0200
schrieb Andreas Neumann <a.neumann at carto.net>:
> Hi Otto,
> If you provide the "visibleLayers" property in the URL, it will be
> used. If you do not provide this property it will use the visibility
> setting from the QGIS project. You need to set
> var useGetProjectSettings = true;
> to be able to use the visibility from the QGIS project. It does not
> work with GetCapabilities.
> Andreas
> On Wed, 28 Aug 2013 12:58:47 +0200, Otto Dassau wrote:
> > Hi,
> > if I want to hide the visibility of a layer in the qgis-weblient, so
> > it is
> > not initially visible when I open the webclient in the browser but it
> > should still be possible to show the layer, if I want.
> > It seems that qgis webclient doesn't understand, if I hide the layer
> > from
> > visibility in the QGIS project.
> > Is there a trick to achieve this?
> > Thanks
> > Otto
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support and analysis
Ackerstrasse 144c , D - 40233 Düsseldorf , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
Community Advisor - QGIS Project Steering Committee
