[Qgis-developer] Processing: a couple of issues
Victor Olaya
volayaf at gmail.com
Thu Aug 29 03:41:52 PDT 2013
> * GRASS appears configured, but it does not run, pretending the path
> is not set; this might be related to the localisation of the path (I'm
> working in Italian SO)
Does it point to the correct GRASS folder? By default it should point
to the OSGeo4W installation, which does not contain any strange
character...
> * the window warning of this issue has a link that should explain, but
> it is broken.
This seems easy to fix, but please fill a ticket if you have time
Thanks!
