[Qgis-developer] [qgis webclient] hide layer in menu
Andreas Neumann
a.neumann at carto.net
Thu Aug 29 07:04:26 PDT 2013
Hi Giovanni,
No - this is not possible yet. We can discuss this in Brighton.
Im about to push a pull-request from Lars Linger and Otto Dassau that
will enable Google/Bing maps as backgrounds - if that interests you. But
you have to stick to EPSG:3857.
Andreas
Am 29.08.2013 15:50, schrieb Giovanni Manghi:
> Hi Andreas,
> there is a way to have a layer always visible but do not have it in the TOC?
> cheers!
>> Hi Otto,
>> If you provide the "visibleLayers" property in the URL, it will be
>> used. If you do not provide this property it will use the visibility
>> setting from the QGIS?project. You need to set
>> var useGetProjectSettings = true;
>> to be able to use the visibility from the QGIS?project. It does not
>> work with GetCapabilities.
> Qgis-developer mailing list
