[Qgis-developer] [qgis webclient] hide layer in menu
Nicolas Boisteault boisteault at observatoire-environnement.org
Thu Aug 29 07:14:27 PDT 2013
Would it be possible to add other backgrounds like openstreetmap or
geoportail.fr for example?
It would be nice if we can select one of the different backgrounds like
in lizmap.
Thanks
Nicolas BOISTEAULT
Développeur Web
Observatoire Régional de l'Environnement Poitou-Charentes
Téléport 4 Antarès - BP 50163 - 86962 Futuroscope Chasseneuil Cedex
Tél : 05 49 49 71 18
*Soyez Eco-responsable, n'imprimez que si nécessaire*
Le 29/08/2013 16:04, Andreas Neumann a écrit :
> Hi Giovanni,
> No - this is not possible yet. We can discuss this in Brighton.
> Im about to push a pull-request from Lars Linger and Otto Dassau that
> will enable Google/Bing maps as backgrounds - if that interests you. But
> you have to stick to EPSG:3857.
> Andreas
> Am 29.08.2013 15:50, schrieb Giovanni Manghi:
>> Hi Andreas,
>> there is a way to have a layer always visible but do not have it in the TOC?
>> cheers!
>>>   Hi Otto,
>>>   If you provide the "visibleLayers" property in the URL, it will be
>>>   used. If you do not provide this property it will use the visibility
>>>   setting from the QGIS?project. You need to set
>>>   var useGetProjectSettings = true;
>>>   to be able to use the visibility from the QGIS?project. It does not
>>>   work with GetCapabilities.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130829/e0cc6c7f/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130829/e0cc6c7f/attachment.jpg>
