[Qgis-developer] [qgis webclient] hide layer in menu
    Otto Dassau
    dassau at gbd-consult.de
    Thu Aug 29 08:09:24 PDT 2013
at the moment only Google and Bing is implemented, but it would be possible
to add OSM and others as well (although I don't know about geoportail.fr).
We plan to improve it in Brighton, because there are still some things
to sort out to make it run properly, e.g. at the moment:
* transparency is not working properly with Layers from QGIS server and
* background layers (Google and Bing) are currently selectable as
  checkboxes together at the same time and this should be changed to radio
  buttons.
So any testing, ideas and solutions from the community are welcome, now that
it is part of qgis-web-client repo.
Regards
Otto
Am Thu, 29 Aug 2013 16:14:27 +0200
schrieb Nicolas Boisteault <boisteault at observatoire-environnement.org>:
> Hi,
> Would it be possible to add other backgrounds like openstreetmap or
> geoportail.fr for example?
> It would be nice if we can select one of the different backgrounds like
> in lizmap.
> Thanks
> Nicolas BOISTEAULT
> Développeur Web
> Observatoire Régional de l'Environnement Poitou-Charentes
> Téléport 4 Antarès - BP 50163 - 86962 Futuroscope Chasseneuil Cedex
> Tél : 05 49 49 71 18
> *Soyez Eco-responsable, n'imprimez que si nécessaire*
> Le 29/08/2013 16:04, Andreas Neumann a écrit :
> > Hi Giovanni,
> > No - this is not possible yet. We can discuss this in Brighton.
> > Im about to push a pull-request from Lars Linger and Otto Dassau that
> > will enable Google/Bing maps as backgrounds - if that interests you. But
> > you have to stick to EPSG:3857.
> > Andreas
> > Am 29.08.2013 15:50, schrieb Giovanni Manghi:
> >> Hi Andreas,
> >> there is a way to have a layer always visible but do not have it in the
> >> TOC?
> >> cheers!
> >>>   Hi Otto,
> >>>   If you provide the "visibleLayers" property in the URL, it will be
> >>>   used. If you do not provide this property it will use the visibility
> >>>   setting from the QGIS?project. You need to set
> >>>   var useGetProjectSettings = true;
> >>>   to be able to use the visibility from the QGIS?project. It does not
> >>>   work with GetCapabilities.
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
