[Qgis-developer] [qgis webclient] hide layer in menu
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Aug 29 07:25:56 PDT 2013
Hi Andreas,
will that be only Google/Bing or will there be a more general approach
to have anything defined as base layer as discussed in [1]?
Bernhard
http://hub.qgis.org/issues/3971
Am 29.08.2013 16:04, schrieb Andreas Neumann:
> Hi Giovanni,
> No - this is not possible yet. We can discuss this in Brighton.
> Im about to push a pull-request from Lars Linger and Otto Dassau that
> will enable Google/Bing maps as backgrounds - if that interests you. But
> you have to stick to EPSG:3857.
> Andreas
> Am 29.08.2013 15:50, schrieb Giovanni Manghi:
>> Hi Andreas,
>> there is a way to have a layer always visible but do not have it in the TOC?
>> cheers!
>>> Hi Otto,
>>> If you provide the "visibleLayers" property in the URL, it will be
>>> used. If you do not provide this property it will use the visibility
>>> setting from the QGIS?project. You need to set
>>> var useGetProjectSettings = true;
>>> to be able to use the visibility from the QGIS?project. It does not
>>> work with GetCapabilities.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> __________ Information from ESET Mail Security, version of virus signature database 8740 (20130829) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 8741 (20130829) __________
http://www.eset.com
