[Qgis-developer] [qgis webclient] hide layer in menu
Andreas Neumann a.neumann at carto.net
Thu Aug 29 07:51:22 PDT 2013
Currently it is only Bing/Google. They plan to add OSM as well.
I personally don't care about this functionality, since I don't need
these base maps and I hate tiles - I think tiles have too many drawbacks
to justify them. If someone comes up with a better, more generic
approach I will accept it.
Also, people who use this functionality in their QGIS web client will
have to explain their users that the background maps are not printable.
Andreas
Am 29.08.2013 16:25, schrieb Bernhard Ströbl:
> Hi Andreas,
> will that be only Google/Bing or will there be a more general approach
> to have anything defined as base layer as discussed in [1]?
> Bernhard
> http://hub.qgis.org/issues/3971
> Am 29.08.2013 16:04, schrieb Andreas Neumann:
>> Hi Giovanni,
>> No - this is not possible yet. We can discuss this in Brighton.
>> Im about to push a pull-request from Lars Linger and Otto Dassau that
>> will enable Google/Bing maps as backgrounds - if that interests you. But
>> you have to stick to EPSG:3857.
>> Andreas
>> Am 29.08.2013 15:50, schrieb Giovanni Manghi:
>>> Hi Andreas,
>>> there is a way to have a layer always visible but do not have it in
>>> the TOC?
>>> cheers!
>>>>   Hi Otto,
>>>>   If you provide the "visibleLayers" property in the URL, it will be
>>>>   used. If you do not provide this property it will use the visibility
>>>>   setting from the QGIS?project. You need to set
>>>>   var useGetProjectSettings = true;
>>>>   to be able to use the visibility from the QGIS?project. It does not
>>>>   work with GetCapabilities.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> __________ Information from ESET Mail Security, version of virus
>> signature database 8740 (20130829) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
> signature database 8741 (20130829) __________
> http://www.eset.com
