[Qgis-developer] Tutorial Atlas
Alexandre Neto
senhor.neto at gmail.com
Thu Aug 29 09:50:13 PDT 2013
I see...
As composer layer, you can use any vector layer available.
If what you are aiming to is some kind of mosaic of all your working area
using smaller maps (like an actual atlas), then you can use vector >
Research tools > Vector Grid, to create the coverage of the all working
area. You will have to figure out the X and Y parameters to fit you pages
scales.
Hope it helps,
Alexandre Neto
On Thu, Aug 29, 2013 at 4:51 PM, Benoît Laurent <blaurent at heurisis.eu>wrote:
> Thank you for your answer.
> Hello,
> I don't know of any tutorial, but, maybe we can help.
> Atlas generation allows you to, for one single map in your print
> composer map, create a set of similar maps, but with different extents,
> labels\titles and even images<http://nyalldawson.net/2013/04/a-neat-trick-in-qgis-2-0-images-in-atlas-prints/>(e.g., a company logo). All this dynamic info must be in a already loaded
> layer.
> This is a point that I don't understand very well: do I have to create
> this layer manually ? Which type is it ?
> At the present time, I just have a raster layer and many differents
> shapefiles containing lines or points.
> Regards,
> Benoît
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130829/f0a404bd/attachment.html>
