[Qgis-developer] Tutorial Atlas
Benoît Laurent
blaurent at heurisis.eu
Thu Aug 29 23:50:57 PDT 2013
Le 29/08/2013 18:50, Alexandre Neto a écrit :
> I see...
> As composer layer, you can use any vector layer available.
> If what you are aiming to is some kind of mosaic of all your working
> area using smaller maps (like an actual atlas), then you can use
> vector > Research tools > Vector Grid, to create the coverage of the
> all working area. You will have to figure out the X and Y parameters
> to fit you pages scales.
I had a try this morning. However, this is not really a mosaic that I
want to create: my different shapefiles can overlap. With the Vector
Grid Tool, I create a regular grid (unless I miss something).
Actually, what I wish to do is to capture the extent of my first
shapefile layer, store it in the composer layer and iterate the process
over the other shapefile layers. Is it possible in QGis ?
As far as I understand, QGis would then rely on this created composer
layer to iterate over each extent. My problem rely lies in the creation
of this composer layer.
Regards,
Benoît
> Hope it helps,
> Alexandre Neto
> On Thu, Aug 29, 2013 at 4:51 PM, Benoît Laurent <blaurent at heurisis.eu
> <mailto:blaurent at heurisis.eu>> wrote:
> Thank you for your answer.
>> Hello,
>> I don't know of any tutorial, but, maybe we can help.
>> Atlas generation allows you to, for one single map in your print
>> composer map, create a set of similar maps, but with different
>> extents, labels\titles and even images
>> <http://nyalldawson.net/2013/04/a-neat-trick-in-qgis-2-0-images-in-atlas-prints/>
>> (e.g., a company logo). All this dynamic info must be in a
>> already loaded layer.
> This is a point that I don't understand very well: do I have to
> create this layer manually ? Which type is it ?
> At the present time, I just have a raster layer and many
> differents shapefiles containing lines or points.
> Regards,
> Benoît
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130830/299d58d9/attachment.html>
