[Qgis-developer] Call for fixes: French and South Africans, raise up
Tim Sutton
lists at linfiniti.com
Fri Aug 30 01:52:22 PDT 2013
Hi
On Mon, Aug 26, 2013 at 12:39 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Frank,
> On Mon, 26. Aug 2013 at 11:18:50 +0200, Frank Sokolic wrote:
> > For the problem with South African CRSs, is this not a simple fix, i.e.
> edit
> > the proj4 parameters in the srs.db file to remove the +axis=wsu options
> from
> > all the Lo CRSs? If so, does anyone know how to do it?
> How isn't the problem (that should be a simple update statement).
> But is that a correct fix? Are there more people annoyed by the current
> entry, than people relying on it? Is the existing EPSG entry wrong?
> Could others from the southern hemisphere comment on that? Tim?
> Basically I don't know who or how the Lo CRS's are being used by others in
the Southern Hemisphere. I think altering the original EPSG projections
should be done upstream if it is really an error. We (South Africans) could
probably whip up a simple plugin that 'corrects' the Lo parameters in the
locally installed QGIS srs.db until such time as the issue is resolved
upstream in EPSG's database.
Regards
Tim
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM) IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130830/d36c2c93/attachment.html>
