[Qgis-developer] Call for fixes: French and South Africans, raise up
rldhont
rldhont at gmail.com
Fri Aug 30 01:57:13 PDT 2013
Hi Tim,
This bug #8487 has a pull request #838
http://hub.qgis.org/issues/8487
https://github.com/qgis/Quantum-GIS/pull/838
Regards,
René-Luc D'Hont
Le 30/08/2013 10:52, Tim Sutton a écrit :
> Hi
> On Mon, Aug 26, 2013 at 12:39 PM, Jürgen E. <jef at norbit.de
> <mailto:jef at norbit.de>> wrote:
> Hi Frank,
> On Mon, 26. Aug 2013 at 11:18:50 +0200, Frank Sokolic wrote:
> > For the problem with South African CRSs, is this not a simple
> fix, i.e. edit
> > the proj4 parameters in the srs.db file to remove the +axis=wsu
> options from
> > all the Lo CRSs? If so, does anyone know how to do it?
> How isn't the problem (that should be a simple update statement).
> But is that a correct fix? Are there more people annoyed by the
> current
> entry, than people relying on it? Is the existing EPSG entry wrong?
> Could others from the southern hemisphere comment on that? Tim?
> Basically I don't know who or how the Lo CRS's are being used by
> others in the Southern Hemisphere. I think altering the original EPSG
> projections should be done upstream if it is really an error. We
> (South Africans) could probably whip up a simple plugin that
> 'corrects' the Lo parameters in the locally installed QGIS srs.db
> until such time as the issue is resolved upstream in EPSG's database.
> Regards
> Tim
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> QGIS PSC member (RM) IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und
> Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net <http://freenode.net>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130830/ddded556/attachment-0001.html>
