[Qgis-developer] [Qgis-user] Shortcut changes in QGIS; call for opinions
A Huarte ahuarte47 at yahoo.es
Sun Dec 1 15:21:39 PST 2013
Hi Bernd, you are right, It would be better that this action would be undoable, and add a layer ... but for the moment there is no such implementation.
Accepting the rule that any action not undaoble must be confirmed by the user, then it seems that deleting a layer should also request a confirmation, right?
Regards
>________________________________
> De: Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
>Para: qgis-developer at lists.osgeo.org
>Enviado: Viernes 29 de noviembre de 2013 1:36
>Asunto: Re: [Qgis-developer] [Qgis-user]  Shortcut changes in QGIS; call for opinions
>Instead of a confirmation when deleting a layer, an Undo-action for
>already deleted layers would be much more helpful.
>Cause you can happily confirm to delete sth, but figure out you were wrong
>just a minute later ...
>Cheers
>Bernd
>Am 29.11.2013, 00:18 Uhr, schrieb A Huarte <ahuarte47 at yahoo.es>:
>> I agree with Nathan.
>> I think that 'D' should ask confirmation, we can imagine the reaction of
>> a user removing accidentaly a configured layer.
>> 'Ctrl+D' could remove layers without confirmation.
>> Alvaro
>>> De: Nathan Woodrow <madmanwoo at gmail.com>
>>> Para: Borys Jurgiel <lists at borysjurgiel.pl>
>>> CC: "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>;
>>> A Huarte <ahuarte47 at yahoo.es>; "qgis-user at lists.osgeo.org"
>>> <qgis-user at lists.osgeo.org>
>>> Enviado: Jueves 28 de noviembre de 2013 23:19
>>> Asunto: Re: [Qgis-user] [Qgis-developer] Shortcut changes in QGIS; call
>>> for opinions
>>> Given that adding/removing a complex layer can be expensive and there
>>> is no undo I would suggest to have a single key shortcut (D) with
>>> confirm and a modified one without (Ctrl-D).  You want to avoid the
>>> user doing something dangerous and in this case that is removing a
>>> layer layer without undo.
>>> - Nathan
>>> On Fri, Nov 29, 2013 at 3:11 AM, Borys Jurgiel <lists at borysjurgiel.pl>
>>> wrote:
>>> Dnia czwartek, 28 listopada 2013 15:11:30 A Huarte pisze:
>>>>> + Remove layer from legend -> Ctrl+D with ask for confirmation.
>>>>>    Now QGIS does not ask for confirmation.
>>>> What about leaving the possibibility to remove the layer without
>>>> confirmation
>>>> with a separate shortcut?
>>>> Actually the first what I do after a fresh install is changing
>>>> "Ctrl-D" to
>>>> simple "D", as I couldn't imagine myself using two fingers for such
>>>> basic
>>>> action like layer removing ;)) The same with a dozen of other Ctrl-*
>>>> shortcuts. And I believe I'm not the only one.
>>>> Regards,
>>>> B.
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131201/bb0b6072/attachment.html>
