[Qgis-developer] [Qgis-user] Shortcut changes in QGIS; call for opinions
A Huarte
ahuarte47 at yahoo.es
Mon Dec 2 04:09:41 PST 2013
Yes, I wondered why a user said he had to remove layers from TOC one by one.
Then remove layer[s] from TOC asking for confirmation seems appropriate becuase of it is not an undoable action, right?
Thank you very much Richard.
>________________________________
> De: Richard Duivenvoorde <rdmailings at duif.net>
>Para: A Huarte <ahuarte47 at yahoo.es>; "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>
>Enviado: Lunes 2 de diciembre de 2013 13:02
>Asunto: Re: [Qgis-developer] [Qgis-user] Shortcut changes in QGIS; call for opinions
>On 02-12-13 00:30, A Huarte wrote:
>> Hi, in QGIS for windows you can select more than one layer (to remove)
>> with the Ctrl key pressed in TOC, this is not possible on other platforms?
>I can use the ctrl-key on debian to select layers in TOC, and 'ctrl-D'
>then removes all selected layers from TOC.
>looks like it is the same on windows?
>Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131202/54122251/attachment.html>
