[Qgis-developer] [Qgis-user] Shortcut changes in QGIS; call for opinions
Marco Bernasocchi
marco at bernawebdesign.ch
Wed Dec 4 06:10:51 PST 2013
on plain ubuntu 13.10 you can also use ctrl.
+1 for your changes, thanks
Marco Bernasocchi (mobile)
http://opengis.ch
On 2 Dec 2013 13:09, "A Huarte" <ahuarte47 at yahoo.es> wrote:
> Yes, I wondered why a user said he had to remove layers from TOC one by
> one.
> Then remove layer[s] from TOC asking for confirmation seems appropriate
> becuase of it is not an undoable action, right?
> Thank you very much Richard.
> *De:* Richard Duivenvoorde <rdmailings at duif.net>
> *Para:* A Huarte <ahuarte47 at yahoo.es>; "qgis-developer at lists.osgeo.org" <
> qgis-developer at lists.osgeo.org>
> *Enviado:* Lunes 2 de diciembre de 2013 13:02
> *Asunto:* Re: [Qgis-developer] [Qgis-user] Shortcut changes in QGIS; call
> for opinions
> On 02-12-13 00:30, A Huarte wrote:
> > Hi, in QGIS for windows you can select more than one layer (to remove)
> > with the Ctrl key pressed in TOC, this is not possible on other
> platforms?
> I can use the ctrl-key on debian to select layers in TOC, and 'ctrl-D'
> then removes all selected layers from TOC.
> looks like it is the same on windows?
> Regards,
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131204/91fcca4d/attachment.html>
