[Qgis-developer] No Zoom to selected point
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue Dec 3 23:45:59 PST 2013
Am 04.12.2013 08:38, schrieb Marco Hugentobler:
> >I have no means to see the particular point I selected and that is
> worse than "unconvenient".
> Of course you have. You know the point is in the middle of the screen,
> so you can manually zoom to it. It is just not convenient :-)
Oh, you are right! But then, wouldn't it be sensible to have the program
do that for me? Maybe zoom to a certain scale that is related to say the
size of the bounding box of the layer? So the scale would be different
for a layer containing global disaster points compared to one containing
local addresses.
Bernhard
> On 04.12.2013 08:19, Bernhard Ströbl wrote:
>> Hi Marco,
>> of course it is undefined, but IMHO something should happen if you
>> click "zoom to selected". If I have a cloud of points and nothing
>> happens I have no means to see the particular point I selected and
>> that is worse than "unconvenient".
>> How does other GIS software handle this problem?
>> Bernhard
>> Am 04.12.2013 07:57, schrieb Marco Hugentobler:
>>> Hi Bernhard
>>> If one point is selected, it is somehow undefined how far to zoom in.
>>> Earlier behaviour was to just zoom in by a factor of two. This however
>>> is very unconvenient if you repeatedly select entries in the attribute
>>> table and click 'zoom to selected'.
>>> Regards,
>>> Marco
>>> On 04.12.2013 07:50, Bernhard Ströbl wrote:
>>>> Hi Gino,
>>>> can you confirm what I described (_one_ point selected, does not zoom)?
>>>> I tried with f21562c on OpenSuse 64 bit.
>>>> Bernhard
>>>> Am 03.12.2013 18:01, schrieb Gino Pirelli:
>>>>> not confirmed in f21562c
>>>>> not confirmed in f1f2e16
>>>>> On 3 December 2013 16:40, Vincent Mora<vincent.mora at oslandia.com>
>>>>> wrote:
>>>>>> I observed the same behavior (qgis master) with two points alligned
>>>>>> on x
>>>>>> (a very simple layer indeed).
>>>>>> On 02/12/2013 12:15, Bernhard Ströbl wrote:
>>>>>>> Dear devs,
>>>>>>> today I stumbled on a strange behaviour when zoooming to a point.
>>>>>>> To reproduce: load a point layer, select one feature in the table
>>>>>>> and
>>>>>>> click "Zoom to selection". The result is the same as if clicking
>>>>>>> "Pan map
>>>>>>> to Selection", i.e the map is panned but not zoomed.
>>>>>>> I _think_ this is because the bounding box of the selected feature
>>>>>>> has a
>>>>>>> width and height of 0. Try iface.activeLayer().
>>>>>>> boundingBoxOfSelected().width()/.height() in the Python console.
>>>>>>> Geometrically speaking this is correct but as the zoom to selected
>>>>>>> function builds on a bounding box with width/height> 0 the outcome
>>>>>>> for the
>>>>>>> user is bad.
>>>>>>> My suggestion would be to define a small rectangle around the
>>>>>>> bounding
>>>>>>> boxes' center if it has size 0 in the zoomToSelected function.
>>>>>>> Tried with QGIS 2.0.1 and current master
>>>>>>> Shall I file a ticket for this?
>>>>>>> Bernhard
>>>>>>> __________ Information from ESET Mail Security, version of virus
>>>>>>> signature database 9119 (20131202) __________
>>>>>>> The message was checked by ESET Mail Security.
>>>>>>> http://www.eset.com
>>>>>>> _______________________________________________
>>>>>>> Qgis-developer mailing list
>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> signature database 9125 (20131203) __________
>>>>> http://www.eset.com
>>>>> http://www.eset.com
>>>> signature database 9127 (20131203) __________
>>>> http://www.eset.com
>> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 9127 (20131203) __________
http://www.eset.com
