[Qgis-developer] No Zoom to selected point
Marco Hugentobler marco.hugentobler at sourcepole.ch
Tue Dec 3 23:52:10 PST 2013
 >Oh, you are right! But then, wouldn't it be sensible to have the
program do that for me? Maybe zoom to a certain scale that is related to
say the size of the bounding box of the
 >layer? So the scale would be different for a layer containing global
disaster points compared to one containing local addresses.
Zoom to a scale related to the layer bbox sounds much better than
zooming in a fixed factor.
Marco
On 04.12.2013 08:45, Bernhard Ströbl wrote:
> Am 04.12.2013 08:38, schrieb Marco Hugentobler:
>>  >I have no means to see the particular point I selected and that is
>> worse than "unconvenient".
>> Of course you have. You know the point is in the middle of the screen,
>> so you can manually zoom to it. It is just not convenient :-)
> to say the size of the bounding box of the layer? So the scale would
> be different for a layer containing global disaster points compared to
> Bernhard
>> On 04.12.2013 08:19, Bernhard Ströbl wrote:
>>> Hi Marco,
>>> of course it is undefined, but IMHO something should happen if you
>>> click "zoom to selected". If I have a cloud of points and nothing
>>> happens I have no means to see the particular point I selected and
>>> that is worse than "unconvenient".
>>> How does other GIS software handle this problem?
>>> Bernhard
>>> Am 04.12.2013 07:57, schrieb Marco Hugentobler:
>>>> Hi Bernhard
>>>> If one point is selected, it is somehow undefined how far to zoom in.
>>>> Earlier behaviour was to just zoom in by a factor of two. This however
>>>> is very unconvenient if you repeatedly select entries in the attribute
>>>> table and click 'zoom to selected'.
>>>> Regards,
>>>> Marco
>>>> On 04.12.2013 07:50, Bernhard Ströbl wrote:
>>>>> Hi Gino,
>>>>> can you confirm what I described (_one_ point selected, does not
>>>>> zoom)?
>>>>> I tried with f21562c on OpenSuse 64 bit.
>>>>> Bernhard
>>>>> Am 03.12.2013 18:01, schrieb Gino Pirelli:
>>>>>> not confirmed in f21562c
>>>>>> not confirmed in f1f2e16
>>>>>> On 3 December 2013 16:40, Vincent Mora<vincent.mora at oslandia.com>
>>>>>> wrote:
>>>>>>> I observed the same behavior (qgis master) with two points alligned
>>>>>>> on x
>>>>>>> (a very simple layer indeed).
>>>>>>> On 02/12/2013 12:15, Bernhard Ströbl wrote:
>>>>>>>> Dear devs,
>>>>>>>> today I stumbled on a strange behaviour when zoooming to a point.
>>>>>>>> To reproduce: load a point layer, select one feature in the table
>>>>>>>> and
>>>>>>>> click "Zoom to selection". The result is the same as if clicking
>>>>>>>> "Pan map
>>>>>>>> to Selection", i.e the map is panned but not zoomed.
>>>>>>>> I _think_ this is because the bounding box of the selected feature
>>>>>>>> has a
>>>>>>>> width and height of 0. Try iface.activeLayer().
>>>>>>>> boundingBoxOfSelected().width()/.height() in the Python console.
>>>>>>>> Geometrically speaking this is correct but as the zoom to selected
>>>>>>>> function builds on a bounding box with width/height> 0 the outcome
>>>>>>>> for the
>>>>>>>> user is bad.
>>>>>>>> My suggestion would be to define a small rectangle around the
>>>>>>>> bounding
>>>>>>>> boxes' center if it has size 0 in the zoomToSelected function.
>>>>>>>> Tried with QGIS 2.0.1 and current master
>>>>>>>> Shall I file a ticket for this?
>>>>>>>> Bernhard
>>>>>>>> __________ Information from ESET Mail Security, version of virus
>>>>>>>> signature database 9119 (20131202) __________
>>>>>>>> The message was checked by ESET Mail Security.
>>>>>>>> http://www.eset.com
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-developer mailing list
>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> signature database 9125 (20131203) __________
>>>>>> http://www.eset.com
>>>>>> http://www.eset.com
>>>>> signature database 9127 (20131203) __________
>>>>> http://www.eset.com
>>> http://www.eset.com
> http://www.eset.com
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
