[Qgis-developer] [Qgis-user] GarminCustomMap-plugin version update to 1.0
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Fri Dec 6 06:07:17 PST 2013
Hi
Good to hear that the plugin is of use.
I am not sure if I understood what you want to achieve.
In general it should be possible to remove the lower limit of the zoom-factor.
However, zooming out and then exporting the Garmin Custom Map / KMZ would give the same result.
Btw, the zoom-factor does not affect the possibility to zoom on your Garmin unit.
Or did you mean something else?
Cheers
Stefan
Sent: 6. desember 2013 14:21
To: Blumentrath, Stefan
Cc: richard at duif.net; qgis-developer at lists.osgeo.org; Qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] GarminCustomMap-plugin version update to 1.0
Great plugin! thanks!
Can the Zoom factor be less than 1.0 so that the map can be viewed on lesser scales also?
Regards
Harish
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131206/5a42a597/attachment.html>
