[Qgis-developer] QGIS Multi-threaded Rendering
Andreas Neumann
a.neumann at carto.net
Fri Dec 13 05:31:45 PST 2013
Hi Martin,
I guess I am also running into the PostgreSQL issue. In general my
PostgreSQL based projects with many layers freeze after a very short
time, while the SpatiaLite based projects work very nicely.
Too many PostgreSQL connections? Can we limit the PostgreSQL connections
or can you better re-use existing connections?
Looks very promising - looking forward to testing my PostgreSQL based
projects once this issue is fixed.
Andreas
Am 12.12.2013 16:46, schrieb Denis Rouzaud:
> Hi Martin,
> So nice to see this close to master!
> Just tried with a big project.
> At launch, I have the database login showing up (since there is too many
> connections apparently):
> And it doesn't stop showing up while in the project
> Will try with a smaller one ;)
> Cheers,
> Denis
