[Qgis-developer] gdalwarp not installed on MacOSX ?
William Kyngesburye
woklist at kyngchaos.com
Mon Dec 30 16:16:05 PST 2013
I might see it if google showed me the image ;)
I can say that gdalwarp IS installed - it's in the GDAL framework. I installed the plugin and it didn't complain. I don't know what to do with the plugin to see if it fails when running it.
My guess is that it needs a configuration option to be able to set the location of gdalwarp. There is an environment variable option in the QGIS prefs that might work - you would add PATH and set it to /Library/Frameworks/GDAL.framework/Versions/1.10/Programs
On Dec 30, 2013, at 5:50 PM, Geo DrinX wrote:
> Hello all,
> as you can see in this image:
> https://drive.google.com/file/d/0Bwg_m86uaXY1R0c0VHk3Sy1HdDA/edit?usp=sharing
> it seems that gdalwarp is not installed (or not found) by Qgis2threejs plugin on MacOSX.
> Could you please help me to solve this ?
> Thank you in advance
> Roberto
> Qgis-developer mailing list
