[Qgis-developer] OpenLayers plugin release and Python API breaks
Etienne Tourigny
etourigny.dev at gmail.com
Fri Feb 1 07:04:13 PST 2013
On Fri, Feb 1, 2013 at 12:40 PM, Angus Carr <angus.carr at gmail.com> wrote:
> Hi,
> I am a plugin developer who was bitten by this API change. It's easily
> worked around with a try...except... structure, but that becomes unneeded
> clutter. I am working on a plugin that I want to work in the future API and
> the stable API at version 1.8, so right now I need that clutter to make it
> work in both versions.
actually it's probably easier doing something like:
if QGis.QGIS_VERSION_INT < 10900:
<use old api>
else:
<use new api>
> I also have the opposite problem, that there are features in the dev API
> that I want to use, but they are not in the stable API. I am thinking of the
> QgsLayer.diagramRenderer() call, which is not found in the older API, even
> though it is in the docs... :-)
> So, I second your adding the addMapLayer() call back in, if only to keep my
> code clutter down :-)
> Cheers,
> Angus Carr.
> On Thu, Jan 31, 2013 at 4:37 PM, Etienne Tourigny <etourigny.dev at gmail.com>
> wrote:
>> On Thu, Jan 24, 2013 at 10:40 AM, Martin Dobias <wonder.sk at gmail.com>
>> wrote:
>> > On Thu, Jan 24, 2013 at 1:32 PM, Alexander Bruy
>> > <alexander.bruy at gmail.com> wrote:
>> >> Hi Pirmin,
>> >> as I can see in API docs (using your link) there is a note:
>> >> Note:
>> >> This method is deprecated since QGIS 1.8, you should use
>> >> addMapLayers rather.
>> > A bit off-topic, but I find it weird that addMapLayer() method has
>> > been marked as deprecated: even if now we have the possibility to
>> > specify more layers at once, it is always good to have a convenience
>> > call that accepts just one layer (as that's what most users will do).
>> I also think that this method should be brought back to the api, see
>> all the errors that are popping up in both mailing list about
>> QgsMapRegistry::addMapLayer().
>> Why break things like this when there is no real gain?
>> Unless someone objects, I will restore QgsMapRegistry::addMapLayer()
>> Etienne
>> > Martin
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
