[Qgis-developer] doxygen warnings
Etienne Tourigny
etourigny.dev at gmail.com
Fri Feb 1 07:37:53 PST 2013
just did a fresh build with apidocs enabled, and came across the
following warnings. I don't know enough about doxygen to fix these,
could someone look into this?
cheers
Etienne
warning: Tag `SHOW_DIRECTORIES' at line 500 of file
/data/src/qgis/qgis-master/build-debug/doc/Doxyfile has become
obsolete.
To avoid this warning please remove this line from your configuration
file or upgrade it using "doxygen -u"
warning: Tag `HTML_ALIGN_MEMBERS' at line 877 of file
obsolete.
warning: Tag `USE_INLINE_TREES' at line 1062 of file
obsolete.
[ 75%] Built target heatmapplugin
[ 75%] [ 75%] Built target sextante_saga_description_stageinstall
Built target python_module_qgis_gui
[ 97%] Built target qgis
[100%] Built target translations
CRS update (inserted:0 updated:0 deleted:0 errors:0)
No CRS updates were necessary.
[100%] Built target synccrsdb
[100%] Built target qgis_coordinatereferencesystemtest
[100%] Built target sextante_saga_help_stageinstall
warning: Included by graph for 'qgis.h' not generated, too many nodes.
Consider increasing DOT_GRAPH_MAX_NODES.
warning: Included by graph for 'qgsfeature.h' not generated, too many
nodes. Consider increasing DOT_GRAPH_MAX_NODES.
warning: Included by graph for 'qgslogger.h' not generated, too many
warning: Included by graph for 'qgsvectorlayer.h' not generated, too
many nodes. Consider increasing DOT_GRAPH_MAX_NODES.
warning: Include graph for 'qgsrasterlayer.cpp' not generated, too
