[Qgis-developer] The future of OpenStreetMap plugin
Martin Dobias
wonder.sk at gmail.com
Sun Feb 3 11:31:20 PST 2013
On Sun, Feb 3, 2013 at 2:54 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> Martin I also support your ideas. From my experience the biggest
> frustration when working with OSM plugin is the unpredictability of
> whether you will be able to fetch al the data in your current extent
> before hitting the OSM API download ceiling.
> Have you looked at using the overpass api rather?
> http://overpass-api.de/
> Its designed for read only applications and is very fast and reliable,
> even when fetching large areas.
Hi Tim
yes that's exactly what I wanted to use for downloads :-)
Apart from not having the limit on downloaded data, it allows various
filtering options.
Martin
