[Qgis-developer] making QgsMapToolIdentify available to plugins
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Feb 7 02:30:59 PST 2013
Hi Radim,
I just finished the work thanks to Jef's debugging ability!
Here is the pull request
https://github.com/qgis/Quantum-GIS/pull/421
The identify method now returns directly the IdentifyResults instead of
using a private attribute.
Also, IdentifyResult is now a single struct (no RasterResult and
VectorResult)
Everything compiles fine and I tested it.
However, could you check that everything is ok regarding to the
rasterChanged?
Also, could you take care of accepting the pull request?
Thanks,
Denis
On 02/07/2013 11:24 AM, Radim Blazek wrote:
> Hi,
> sorry, I do not use IRC usually.
> I would like to return to work in identify tool areas next week:
> - copy feature from context menu
> - better tree hierarchy for rasters
> - propagate errors to user - probably just error messages as texts in tree
> - instead of all that signals on format change just listen in action
> and then call QgsMapToolIdentify and dialog functions
> Please let me know when you finish your work in identify tool so that
> we avoid conflicts.
> Radim
> On Thu, Feb 7, 2013 at 10:04 AM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>> Hi Radim,
>> I have already merged the changes to return directly the results.
>> I am currently making a single struct for the results. I have a problem with
>> python files, an error in compilation I am trying to solve for some time now
>> without any success...
>> Would you have some time to give me hand?
>> Are you on IRC?
>> Thanks
>> Denis
>> On 02/06/2013 05:07 PM, Radim Blazek wrote:
>>>> Also, your changes to the raster result structure made me think that we
>>>> could use a single struct for both vector and raster result.
>>>> It might be easier to look into the results.
>>>> Any opinion on this? Nathan?
>>> I believe, that It would be better to pass results to the dialog in
>>> the original hierarchical structure instead of splitting them to
>>> individual results and then reconstruct the tree searching for the
>>> layer it should go into. For rasters the logical structure may vary
>>> form one level for raster values (I would prefer to put band values
>>> directly into layer item instead of adding additional level "feature")
>>> to four levels for WMS with layer-sublayer-featuretype-feature.
>>> Maybe some parts of QgsMapToolIdentify::identifyVectorLayer and
>>> QgsMapToolIdentify::identifyRasterLayer, those related to creation the
>>> tree in dialog should better be moved to QgsIdentifyResultsDialog?
>>> I'll possibly add QgsRasterIdentifyResult and the dialog could work
>>> directly with that or to use current QList<QVariant> returned from
>>> raster identify().
>> yes,
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130207/0139328e/attachment.html>
