[Qgis-developer] Dual View: Call for feedback
Josef K groundwatergis at gmail.com
Thu Feb 7 14:05:19 PST 2013
Hi Matthias
I wanted to see how custom edit forms will be integrated with the dual
view, in particular a few forms that I use quite a lot (see [1] and [2]).
Therefore I tried to build qgis from your dual-view source but I must have
done something wrong. I got qgis running but when I load a vector layer I
get these warnings:
Warning: Object::connect: No such signal QgsVectorLayer::layerModified(
bool )
Warning: Object::connect:  (receiver name: 'QgisApp')
When I try to open the attribute table an exception pop-up says "Syntax
error, unexpected $end". The terminal shows:
Warning: Object::connect: No such signal QgsAttributeTableView::progress(
int, bool & )
Warning: Object::connect:  (sender name:   'mTableView')
Warning: Object::connect:  (receiver name: 'QgsAttributeTableDialog')
Warning: Object::connect: No such slot QgsAttributeTableDialog::finished()
Warning: QLayout: Cannot add null widget to
QVBoxLayout/mAttributeEditorLayout
I guess this is my fault not being able to build correctly from source and
I will probably not spend more time trying. Still, I thought I would give
you this short report and also point out that we are a few users that are
highly interested in how the dual view will integrate with custom edit
forms. Perhaps there could be an extra slide in your presentation that
gives an example of that?
kind regards
Josef
[1]
https://sites.google.com/site/midvattenpluginforqgis/nnnn#TOC-Add-single-water-level-measurement-or-single-stratigraphy-layer-information
[2]
https://sites.google.com/site/midvattenpluginforqgis/nnnn#TOC-Add-observation-points-and-lines
> To: QGIS Developer Mailing List <qgis-developer at lists.osgeo.org>
> Cc:
> Date: Fri, 01 Feb 2013 15:11:01 +0100
> Subject: [Qgis-developer] Dual View: Call for feedback
> Hi everybody,
> I'm pleased to announce that I've pushed the current state of dual-view to
> github [1]
> Anybody interested in having a look at it is kindly requested to do so and
> share his thoughts concerning the development.
> Anybody who does not want or can't compile the branch can easily have a
> look at the slides from this presentation [2] which should cover the basics
> as well (There's a small sample video to show the live filter inside).
> Any feedback is appreciated.
> If there is no strong rejection of these ideas, I'd like to request a
> merge in two weeks, after I cleaned up the code and reviewed the code for
> layers with no "feature by id" capabilities (which need to be fully cached).
> I will be out of office next week, so please bear with me, if I only reply
> to your feedback in the second week of February.
> Kind regards,
> Matthias
> [1] https://github.com/matthias-**kuhn/Quantum-GIS/tree/dual-**view<https://github.com/matthias-kuhn/Quantum-GIS/tree/dual-view><
> [2] http://qgis.vitu.ch/download/**dual-view-presentation.odp<http://qgis.vitu.ch/download/dual-view-presentation.odp>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130207/f79a1d44/attachment.html>
