[Qgis-developer] Dual View: Call for feedback
Matthias Kuhn matthias.kuhn at gmx.ch
Sat Feb 9 03:07:46 PST 2013
Hi Josef,
Thank you for testing
Custom edit forms should integrate nicely with dual view (Custom
.ui-forms or Drag and drop forms).
You can ignore all these warnings, they shouldn't harm. As far as I can
see, the exception points to the real problem connected to qgsexpression.
In the feature list, the preview text uses qgsexpression and tries to
display by default (in this order)
- display field ( vector layer property )
- primary key (in case of multiple pk's separated by a comma )
Maybe your display field name has special characters (spaces...)?
Would it be possible to let me have a look at the qgs-File you loaded?
Regards,
Matthias
On 02/07/2013 11:05 PM, Josef K wrote:
> Hi Matthias
> I wanted to see how custom edit forms will be integrated with the dual
> view, in particular a few forms that I use quite a lot (see [1] and
> [2]). Therefore I tried to build qgis from your dual-view source but I
> must have done something wrong. I got qgis running but when I load a
> vector layer I get these warnings:
> Warning: Object::connect: No such signal
> QgsVectorLayer::layerModified( bool )
> Warning: Object::connect:  (receiver name: 'QgisApp')
> When I try to open the attribute table an exception pop-up says
> "Syntax error, unexpected $end". The terminal shows:
> QgsAttributeTableView::progress( int, bool & )
> Warning: Object::connect:  (sender name:   'mTableView')
> Warning: Object::connect:  (receiver name: 'QgsAttributeTableDialog')
> Warning: Object::connect: No such slot QgsAttributeTableDialog::finished()
> Warning: QLayout: Cannot add null widget to
> QVBoxLayout/mAttributeEditorLayout
> I guess this is my fault not being able to build correctly from source
> and I will probably not spend more time trying. Still, I thought I
> would give you this short report and also point out that we are a few
> users that are highly interested in how the dual view will integrate
> with custom edit forms. Perhaps there could be an extra slide in your
> presentation that gives an example of that?
> kind regards
> Josef
> [1]
> https://sites.google.com/site/midvattenpluginforqgis/nnnn#TOC-Add-single-water-level-measurement-or-single-stratigraphy-layer-information
> [2]
> https://sites.google.com/site/midvattenpluginforqgis/nnnn#TOC-Add-observation-points-and-lines
>     From: Matthias Kuhn <matthias.kuhn at gmx.ch
>     <mailto:matthias.kuhn at gmx.ch>>
>     To: QGIS Developer Mailing List <qgis-developer at lists.osgeo.org
>     <mailto:qgis-developer at lists.osgeo.org>>
>     Cc:
>     Date: Fri, 01 Feb 2013 15:11:01 +0100
>     Subject: [Qgis-developer] Dual View: Call for feedback
>     Hi everybody,
>     I'm pleased to announce that I've pushed the current state of
>     dual-view to github [1]
>     Anybody interested in having a look at it is kindly requested to
>     do so and share his thoughts concerning the development.
>     Anybody who does not want or can't compile the branch can easily
>     have a look at the slides from this presentation [2] which should
>     cover the basics as well (There's a small sample video to show the
>     live filter inside).
>     Any feedback is appreciated.
>     If there is no strong rejection of these ideas, I'd like to
>     request a merge in two weeks, after I cleaned up the code and
>     reviewed the code for layers with no "feature by id" capabilities
>     (which need to be fully cached).
>     I will be out of office next week, so please bear with me, if I
>     only reply to your feedback in the second week of February.
>     Kind regards,
>     Matthias
>     [1] https://github.com/matthias-kuhn/Quantum-GIS/tree/dual-view
>     <https://github.com/matthias-kuhn/Quantum-GIS/tree/dual-view>
>     [2] http://qgis.vitu.ch/download/dual-view-presentation.odp
> Qgis-developer mailing list
