[Qgis-developer] Dual View: Call for feedback
Matthias Kuhn
matthias.kuhn at gmx.ch
Sat Feb 9 04:04:06 PST 2013
Hi Josef,
I fixed an issue which could be responsible for the problem you described.
The mentioned popup also appeared if there is a) no display field
defined and b) no primary key defined. In this case the list will now
display all fields, separated by a comma.
Regards,
Matthias
On 02/09/2013 12:07 PM, Matthias Kuhn wrote:
> Hi Josef,
> Thank you for testing
> Custom edit forms should integrate nicely with dual view (Custom
> .ui-forms or Drag and drop forms).
> You can ignore all these warnings, they shouldn't harm. As far as I
> can see, the exception points to the real problem connected to
> qgsexpression.
> In the feature list, the preview text uses qgsexpression and tries to
> display by default (in this order)
> - display field ( vector layer property )
> - primary key (in case of multiple pk's separated by a comma )
> Maybe your display field name has special characters (spaces...)?
> Would it be possible to let me have a look at the qgs-File you loaded?
> Regards,
> Matthias
> On 02/07/2013 11:05 PM, Josef K wrote:
>> Hi Matthias
>> I wanted to see how custom edit forms will be integrated with the
>> dual view, in particular a few forms that I use quite a lot (see [1]
>> and [2]). Therefore I tried to build qgis from your dual-view source
>> but I must have done something wrong. I got qgis running but when I
>> load a vector layer I get these warnings:
>> Warning: Object::connect: No such signal
>> QgsVectorLayer::layerModified( bool )
>> Warning: Object::connect: (receiver name: 'QgisApp')
>> When I try to open the attribute table an exception pop-up says
>> "Syntax error, unexpected $end". The terminal shows:
>> QgsAttributeTableView::progress( int, bool & )
>> Warning: Object::connect: (sender name: 'mTableView')
>> Warning: Object::connect: (receiver name: 'QgsAttributeTableDialog')
>> Warning: Object::connect: No such slot
>> QgsAttributeTableDialog::finished()
>> Warning: QLayout: Cannot add null widget to
>> QVBoxLayout/mAttributeEditorLayout
>> I guess this is my fault not being able to build correctly from
>> source and I will probably not spend more time trying. Still, I
>> thought I would give you this short report and also point out that we
>> are a few users that are highly interested in how the dual view will
>> integrate with custom edit forms. Perhaps there could be an extra
>> slide in your presentation that gives an example of that?
>> kind regards
>> Josef
>> [1]
>> https://sites.google.com/site/midvattenpluginforqgis/nnnn#TOC-Add-single-water-level-measurement-or-single-stratigraphy-layer-information
>> [2]
>> https://sites.google.com/site/midvattenpluginforqgis/nnnn#TOC-Add-observation-points-and-lines
>> From: Matthias Kuhn <matthias.kuhn at gmx.ch
>> <mailto:matthias.kuhn at gmx.ch>>
>> To: QGIS Developer Mailing List <qgis-developer at lists.osgeo.org
>> <mailto:qgis-developer at lists.osgeo.org>>
>> Cc:
>> Date: Fri, 01 Feb 2013 15:11:01 +0100
>> Subject: [Qgis-developer] Dual View: Call for feedback
>> Hi everybody,
>> I'm pleased to announce that I've pushed the current state of
>> dual-view to github [1]
>> Anybody interested in having a look at it is kindly requested to
>> do so and share his thoughts concerning the development.
>> Anybody who does not want or can't compile the branch can easily
>> have a look at the slides from this presentation [2] which should
>> cover the basics as well (There's a small sample video to show the
>> live filter inside).
>> Any feedback is appreciated.
>> If there is no strong rejection of these ideas, I'd like to
>> request a merge in two weeks, after I cleaned up the code and
>> reviewed the code for layers with no "feature by id" capabilities
>> (which need to be fully cached).
>> I will be out of office next week, so please bear with me, if I
>> only reply to your feedback in the second week of February.
>> Kind regards,
>> Matthias
>> [1] https://github.com/matthias-kuhn/Quantum-GIS/tree/dual-view
>> <https://github.com/matthias-kuhn/Quantum-GIS/tree/dual-view>
>> [2] http://qgis.vitu.ch/download/dual-view-presentation.odp
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
