[Qgis-developer] Dual View: Call for feedback
Josef K
groundwatergis at gmail.com
Mon Feb 11 04:19:49 PST 2013
Hi Matthias
It works fine now. The warnings remains unchanged but I can open the
attribute tables for vector layers without a defined display field.
As you said, custom edit forms integrate quite nicely, at least if they are
well designed to start with. I had a few forms which did not fit too well
into the dual view window but I will just change from horizontal to
vertical layout and everything will be fine.
My overall impression is that it looks nice and that the dual view will be
a great enhancement.
One thing that confused me a bit is that my selection in the map, which
corresponds to the same selection in the classic attribute table, is not
seen in the new 'feature list vew' (what is it called?). I can see there
are advantages with this approach but I think it would cause less confusion
if there was the same selection in all three 'vews': map-attribute
table-feature list. See this [1] example where a user may be mislead to
fill in data for well02 since that is selected on map, or well01 since that
is highlighted in the list.
I also thought of another possible enhancement related to non-spatial
tables. When I have a table loaded into qgis as a non-spatial vector layer,
then I use the plus sign in the attribute table to add features - and an
edit form pops up. I think it would be nice if that edit form showed up in
the new attribute table feature list view instead. Because, when it comes
to non-spatial data, I see no reason to have that edit form pop-up on the
of the map view. (But of course this is the preferred behaviour when adding
new features to a spatial layer.)
Anyway, the dual-view seems like a great improvement and I appreciate that.
Thank you!
Regards
Josef
[1]
https://docs.google.com/file/d/0B1vhrFUx2OZBSjRpSkozenFQRnc/edit?usp=sharing
> To: qgis-developer at lists.osgeo.org
> Date: Sat, 09 Feb 2013 13:04:06 +0100
> Subject: Re: [Qgis-developer] Dual View: Call for feedback
> Hi Josef,
> I fixed an issue which could be responsible for the problem you described.
> The mentioned popup also appeared if there is a) no display field defined
> and b) no primary key defined. In this case the list will now display all
> fields, separated by a comma.
> Regards,
> Matthias
> On 02/09/2013 12:07 PM, Matthias Kuhn wrote:
>> Hi Josef,
>> Thank you for testing
>> Custom edit forms should integrate nicely with dual view (Custom
>> .ui-forms or Drag and drop forms).
>> You can ignore all these warnings, they shouldn't harm. As far as I can
>> see, the exception points to the real problem connected to qgsexpression.
>> In the feature list, the preview text uses qgsexpression and tries to
>> display by default (in this order)
>> - display field ( vector layer property )
>> - primary key (in case of multiple pk's separated by a comma )
>> Maybe your display field name has special characters (spaces...)?
>> Would it be possible to let me have a look at the qgs-File you loaded?
>> Regards,
>> Matthias
>> On 02/07/2013 11:05 PM, Josef K wrote:
>>> Hi Matthias
>>> I wanted to see how custom edit forms will be integrated with the dual
>>> view, in particular a few forms that I use quite a lot (see [1] and [2]).
>>> Therefore I tried to build qgis from your dual-view source but I must have
>>> done something wrong. I got qgis running but when I load a vector layer I
>>> get these warnings:
>>> Warning: Object::connect: No such signal QgsVectorLayer::layerModified(
>>> bool )
>>> Warning: Object::connect: (receiver name: 'QgisApp')
>>> When I try to open the attribute table an exception pop-up says "Syntax
>>> error, unexpected $end". The terminal shows:
>>> Warning: Object::connect: No such signal QgsAttributeTableView::**progress(
>>> int, bool & )
>>> Warning: Object::connect: (sender name: 'mTableView')
>>> Warning: Object::connect: (receiver name: 'QgsAttributeTableDialog')
>>> Warning: Object::connect: No such slot QgsAttributeTableDialog::**
>>> finished()
>>> Warning: QLayout: Cannot add null widget to QVBoxLayout/**
>>> mAttributeEditorLayout
>>> I guess this is my fault not being able to build correctly from source
>>> and I will probably not spend more time trying. Still, I thought I would
>>> give you this short report and also point out that we are a few users that
>>> are highly interested in how the dual view will integrate with custom edit
>>> forms. Perhaps there could be an extra slide in your presentation that
>>> gives an example of that?
>>> kind regards
>>> Josef
>>> [1] https://sites.google.com/site/**midvattenpluginforqgis/nnnn#**
>>> TOC-Add-single-water-level-**measurement-or-single-**
>>> stratigraphy-layer-information<https://sites.google.com/site/midvattenpluginforqgis/nnnn#TOC-Add-single-water-level-measurement-or-single-stratigraphy-layer-information>
>>> [2] https://sites.google.com/site/**midvattenpluginforqgis/nnnn#**
>>> TOC-Add-observation-points-**and-lines<https://sites.google.com/site/midvattenpluginforqgis/nnnn#TOC-Add-observation-points-and-lines>
>>> From: Matthias Kuhn <matthias.kuhn at gmx.ch
>>> <mailto:matthias.kuhn at gmx.ch>>
>>> To: QGIS Developer Mailing List <qgis-developer at lists.osgeo.**org<qgis-developer at lists.osgeo.org>
>>> <mailto:qgis-developer at lists.**osgeo.org<qgis-developer at lists.osgeo.org>
>>> Cc:
>>> Date: Fri, 01 Feb 2013 15:11:01 +0100
>>> Subject: [Qgis-developer] Dual View: Call for feedback
>>> Hi everybody,
>>> I'm pleased to announce that I've pushed the current state of
>>> dual-view to github [1]
>>> Anybody interested in having a look at it is kindly requested to
>>> do so and share his thoughts concerning the development.
>>> Anybody who does not want or can't compile the branch can easily
>>> have a look at the slides from this presentation [2] which should
>>> cover the basics as well (There's a small sample video to show the
>>> live filter inside).
>>> Any feedback is appreciated.
>>> If there is no strong rejection of these ideas, I'd like to
>>> request a merge in two weeks, after I cleaned up the code and
>>> reviewed the code for layers with no "feature by id" capabilities
>>> (which need to be fully cached).
>>> I will be out of office next week, so please bear with me, if I
>>> only reply to your feedback in the second week of February.
>>> Kind regards,
>>> Matthias
>>> [1] https://github.com/matthias-**kuhn/Quantum-GIS/tree/dual-**view<https://github.com/matthias-kuhn/Quantum-GIS/tree/dual-view>
>>> <https://github.com/matthias-**kuhn/Quantum-GIS/tree/dual-**view<https://github.com/matthias-kuhn/Quantum-GIS/tree/dual-view>
>>> [2] http://qgis.vitu.ch/download/**dual-view-presentation.odp<http://qgis.vitu.ch/download/dual-view-presentation.odp>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130211/c190fe51/attachment-0001.html>
