[Qgis-developer] Several errors
Sanghee Shin
endofcap at gmail.com
Tue Feb 12 20:25:38 PST 2013
I prepared new clean windows and installed master version there. Finally I found that srs.db was successfully updated and got all SRSs that I needed.
I assume that old environment settings like path & others from old QGIS or other FOSS4G affected the post-installation process.
Do I need to cancel the ticket?
Sanghee
2013. 2. 13., 오후 1:02, Sanghee Shin <endofcap at gmail.com> 작성:
> Hi,
> I run crssync manually and I found that crssync tried to update srs.db in wrong path. So for my testing, I created folder and put the srs.db there and re-run the crssync. Finally I got the updated srs.db successfully. Wow!
> I think it's not the problem or bug of crssync but the problem of post-installation process in master version.
> I'll test more.
> Thanks.
> Sanghee
> Windows :
> Synchronizing CRS database with GDAL/PROJ definitions.
> Could not open database: C:/Programme/OSGeo4W/apps/qgis-dev/./resources/srs.db [unable to open database file]
> Mac OSX :
> Could not open database: /Users/larrys/QGIS/nightly/QGIS_Apps/QGIS_2.0-dev.app/Contents/MacOS/../Resources/resources/srs.db [unable to open database file]
> 2013. 2. 13., 오전 3:27, Andre Joost <andre+joost at nurfuerspam.de> 작성:
>> Am 12.02.2013 18:53, schrieb Sanghee Shin:
>>> Hi,
>>> I updated my ticket and also attached setup.log.full there for your digging.
>> Looks like a QT dll version problem:
>> <http://stackoverflow.com/questions/11293337/qt-exited-with-code-1073741511>
>> http://www.qtcentre.org/threads/26213-exited-with-code-1073741511
>> http://www.qtcentre.org/threads/26604-Runtime-problem-in-Release-mode
>> Do you have any other version of QT on your system, which brings a false dll into the Windows path?
>>> I just wonder whether there is any similar post-installation log file in Mac OSX and Ubuntu.
>> Sorry, not my world ;-)
>> Greetings,
>> André Joost
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
