[Qgis-developer] Several errors
Andre Joost
andre+joost at nurfuerspam.de
Tue Feb 12 22:17:22 PST 2013
Am 13.02.2013 05:25, schrieb Sanghee Shin:
> I prepared new clean windows and installed master version there.
> Finally I found that srs.db was successfully updated and got all SRSs
> that I needed.
> I assume that old environment settings like path& others from old
> QGIS or other FOSS4G affected the post-installation process.
> Do I need to cancel the ticket?
Maybe it is better to close that, and open another for the installer fault.
>> Windows : Synchronizing CRS database with GDAL/PROJ definitions.
>> Could not open database:
>> C:/Programme/OSGeo4W/apps/qgis-dev/./resources/srs.db [unable to
>> open database file]
This is definitely the wrong path. I wonder how you got the
C:\Programme\ in there. Thats the german language folder name for
Windows XP C:\Program Data\
For OSGeo4w setup, it should be C:\Osgeo4W\
Greetings,
André Joost
