[Qgis-developer] qgis web client small bug?
Andreas Neumann
a.neumann at carto.net
Sun Feb 17 03:20:26 PST 2013
Hi Paolo,
The layer drawing order only works if you have a newer release of QGIS
server - one that does support and use the GetProjectSettings command
(instead of the GetCapabilities command before). Only if you use that
server version - and also have GetProjectSettings enabled in the QGIS
webclient - the layer drawing order should work.
Can you please check and report back? I can only check it it on Tuesday,
when I am back at my workplace, but I can tell that the layer drawing
order successfully works in some of my projects.
Andreas
Am 14.02.2013 11:54, schrieb Paolo Cavallini:
> Hi all.
> I do not know if this has already be mentioned, but if the layer drawing order is
> activated in a project (as it is in the naturalearth project) some of the layers are
> not visible.
> Hope this helps.
> All the best.
