[Qgis-developer] qgis web client small bug?
Paolo Cavallini
cavallini at faunalia.it
Mon Feb 18 02:31:37 PST 2013
Il 17/02/2013 12:20, Andreas Neumann ha scritto:
> The layer drawing order only works if you have a newer release of QGIS
> server - one that does support and use the GetProjectSettings command
> (instead of the GetCapabilities command before). Only if you use that
> server version - and also have GetProjectSettings enabled in the QGIS
> webclient - the layer drawing order should work.
> Can you please check and report back? I can only check it it on Tuesday,
> when I am back at my workplace, but I can tell that the layer drawing
> order successfully works in some of my projects.
Hi Andreas,
thanks for your reply. We are using qgis master, so this should not be
an issue.
Can you see all the layers switched on on the demo Natural Earth
project, out of the box?
A minor annoyance anyway.
Thanks again.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
