[Qgis-developer] Update of composer item's GUI (Pull Request)
Larry Shaffer larrys at dakotacarto.com
Tue Feb 19 01:54:33 PST 2013
This has been worked on some more, tested on Ubuntu 12.10, Mac 10.7 and
Win7, then committed [0]. If you find any issues with the new layout please
let Olivier or I know.
Along the way we fixed some issues with the new collapsible group boxes,
which are prominently used. If you see any issue with them (even small
ones), please let me know. Try Ctrl(or Alt)-clicking them to toggle synched
sets of group boxes.
Thanks to Olivier for initiating and working out the redesign!
Regards,
Larry
[0] https://github.com/qgis/Quantum-GIS/compare/a645f43f67da...0f0c981143c7
On Tue, Feb 12, 2013 at 11:00 AM, kimaidou <kimaidou at gmail.com> wrote:
> Hi Olivier
> +1 for me, this looks much better. Thanks for this work.
> 2013/2/12 Olivier Dalang <olivier.dalang at gmail.com>
>> Hi !
>> I've made a pull request that induces some changes in the Composer's
>> items GUI.
>> If you are interested, please have a look (feedback is of course welcome)
>> https://github.com/qgis/Quantum-GIS/pull/426
>> Best regards,
>> Olivier
>> The differencesQToolBox replaced by QCollapsibleGroupBox(es).
>> *before*
>>    - a lot of wasted space
>>    - unpractical (you must toggle back and forth to edit elements on
>>    different pages)
>>    - not very good looking (it looks messy and it's hard to distinguigh
>>    from QDockWindowss)
>> *after*
>>    - QgsCollapsibleGroupBoxes look great and provide a nice outline of
>>    all features when folded
>>    - Easier to adapt to your needs and screen size
>>    - so you can dynamically reposition/resize the items without having
>>    to open a modal dialog.
>>    - also provides a nice feedback on element's position
>> Harmonisation and optimisation of widget layouts
>>    - most of the widgets had uneven spacing (looked a bit sketchy)
>>    - some widgets where uselessly big
>>    - better hiearchy and grouping of similar options
>> Duplicate/Ambigious/Unclear functionalities
>>    - QgsComposerShape had duplicate implemtation of frame and background
>> Changes
>> The work was mainly done in the .ui files, but some classes are a little
>> more modified :
>>    - QgsComposerShape (clean duplicate frame/background implementation)
>>    - QgsItemPositionDialog was merged into QgsComposerItemWidget, which
>>    also makes some change
>> Screenshots
>> Here are screenshots of all modified widgets :
>> https://www.dropbox.com/sh/gkte3o126doe4ue/YfN_iVxRKx
>>  Todo
>>    - I think it would be nice to integrate the atlas' widget into the
>>    composition's widget
>>    - It would be nice if there was a collapse/expand all button (or a
>>    shortcut (alt-click ?) to collapse all other QgsCollapsibleBoxes)
>>    - Use color buttons wherever possible
>> So...
>> What do you think ?
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130219/7cfc1386/attachment-0001.html>
