[Qgis-developer] Update of composer item's GUI (Pull Request)
kimaidou
kimaidou at gmail.com
Tue Feb 12 10:00:39 PST 2013
Hi Olivier
+1 for me, this looks much better. Thanks for this work.
2013/2/12 Olivier Dalang <olivier.dalang at gmail.com>
> Hi !
> I've made a pull request that induces some changes in the Composer's items
> GUI.
> If you are interested, please have a look (feedback is of course welcome)
> https://github.com/qgis/Quantum-GIS/pull/426
> Best regards,
> Olivier
> The differencesQToolBox replaced by QCollapsibleGroupBox(es).
> *before*
> - a lot of wasted space
> - unpractical (you must toggle back and forth to edit elements on
> different pages)
> - not very good looking (it looks messy and it's hard to distinguigh
> from QDockWindowss)
> *after*
> - QgsCollapsibleGroupBoxes look great and provide a nice outline of
> all features when folded
> - Easier to adapt to your needs and screen size
> - so you can dynamically reposition/resize the items without having to
> open a modal dialog.
> - also provides a nice feedback on element's position
> Harmonisation and optimisation of widget layouts
> - most of the widgets had uneven spacing (looked a bit sketchy)
> - some widgets where uselessly big
> - better hiearchy and grouping of similar options
> Duplicate/Ambigious/Unclear functionalities
> - QgsComposerShape had duplicate implemtation of frame and background
> Changes
> The work was mainly done in the .ui files, but some classes are a little
> more modified :
> - QgsComposerShape (clean duplicate frame/background implementation)
> - QgsItemPositionDialog was merged into QgsComposerItemWidget, which
> also makes some change
> Screenshots
> Here are screenshots of all modified widgets :
> https://www.dropbox.com/sh/gkte3o126doe4ue/YfN_iVxRKx
> Todo
> - I think it would be nice to integrate the atlas' widget into the
> composition's widget
> - It would be nice if there was a collapse/expand all button (or a
> shortcut (alt-click ?) to collapse all other QgsCollapsibleBoxes)
> - Use color buttons wherever possible
> So...
> What do you think ?
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130212/da17906f/attachment-0001.html>
