[Qgis-developer] attributeMap vs. attributes
Victor Olaya volayaf at gmail.com
Tue Feb 19 02:36:13 PST 2013
I faced the same problem with SEXTANTE (and there were a large number
of calls to replace), and decided to go ahead and break compatibility
with 1.8. Should be better in the mid-term, but it's true that it is
not nice to leave a plugin depending now on an yet-unreleased
version...
If it is not a big work, maybe you can keep two versions, more or less
synchronized
Victor
2013/2/19 Sandro Santilli <strk at keybit.net>:
> My topological editing plugin broke due to attributeMap() being replaced
> by attributes() in the python API. If I change to use attributes() it won't
> work with 1.8 anymore. Is there any important reason to require changes in
> all plugins ?
> --strk;
> Qgis-developer mailing list
