[Qgis-developer] attributeMap vs. attributes
Sandro Santilli strk at keybit.net
Tue Feb 19 02:39:25 PST 2013
On Tue, Feb 19, 2013 at 11:36:13AM +0100, Victor Olaya wrote:
> I faced the same problem with SEXTANTE (and there were a large number
> of calls to replace), and decided to go ahead and break compatibility
> with 1.8. Should be better in the mid-term, but it's true that it is
> not nice to leave a plugin depending now on an yet-unreleased
> version...
> If it is not a big work, maybe you can keep two versions, more or less
> synchronized
I can try that. How do I encode that one version does NOT work
with a newer QGIS ?
I see there's a qgisMinimumVersion setting,
is there also a qgisMaximumVersion ? Would it be used by plugin fetcher ?
--strk;
