[Qgis-developer] attributeMap vs. attributes
Victor Olaya
volayaf at gmail.com
Tue Feb 19 02:53:13 PST 2013
The ideas in the document that Richard mentions, about how to make it
compatible for both versions, are maybe a better idea. I do not know
if a maximum version can be set in the plugin metadata. :-(
Regards
Victor
2013/2/19 Sandro Santilli <strk at keybit.net>:
> On Tue, Feb 19, 2013 at 11:36:13AM +0100, Victor Olaya wrote:
>> I faced the same problem with SEXTANTE (and there were a large number
>> of calls to replace), and decided to go ahead and break compatibility
>> with 1.8. Should be better in the mid-term, but it's true that it is
>> not nice to leave a plugin depending now on an yet-unreleased
>> version...
>> If it is not a big work, maybe you can keep two versions, more or less
>> synchronized
> I can try that. How do I encode that one version does NOT work
> with a newer QGIS ?
> I see there's a qgisMinimumVersion setting,
> is there also a qgisMaximumVersion ? Would it be used by plugin fetcher ?
> --strk;
