[Qgis-developer] attributeMap vs. attributes
Nathan Woodrow madmanwoo at gmail.com
Tue Feb 19 02:54:55 PST 2013
Why not just hide it using Python method overriding:
QgsVectorLayer.attributeMap = QgsVectorLayer.attributes
Then you can just call attributesMap()[] and it will call
QgsVectorLayer.attributes for you.
- Nathan
On Tue, Feb 19, 2013 at 8:53 PM, Victor Olaya <volayaf at gmail.com> wrote:
> The ideas in the document that Richard mentions, about how to make it
> compatible for both versions, are maybe a better idea. I do not know
> if a maximum version can be set in the plugin metadata. :-(
> Regards
> Victor
> 2013/2/19 Sandro Santilli <strk at keybit.net>:
> > On Tue, Feb 19, 2013 at 11:36:13AM +0100, Victor Olaya wrote:
> >> I faced the same problem with SEXTANTE (and there were a large number
> >> of calls to replace), and decided to go ahead and break compatibility
> >> with 1.8. Should be better in the mid-term, but it's true that it is
> >> not nice to leave a plugin depending now on an yet-unreleased
> >> version...
> >> If it is not a big work, maybe you can keep two versions, more or less
> >> synchronized
> > I can try that. How do I encode that one version does NOT work
> > with a newer QGIS ?
> > I see there's a qgisMinimumVersion setting,
> > is there also a qgisMaximumVersion ? Would it be used by plugin fetcher ?
> > --strk;
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130219/58e4dd6d/attachment.html>
