[Qgis-developer] WPS plugin
Tyler Mitchell
info at locatepress.com
Tue Feb 19 15:18:54 PST 2013
On 2013-01-10, at 2:19 AM, Luca Delucchi wrote:
> 2013/1/10 Paolo Cavallini <cavallini at faunalia.it>:
>> Hi all.
>> Testing the just upgrades WPS plugin, with geodati.fmach.it, module v_voronoi,
>> results in:
>> It seems QGIS cannot load the result of the process. The result has a 'text/xml' type
>> and can be accessed at '/tmp/qt_temp.jL9396.gml'.
>> You could ask the service provider to consider changing the default data type of the
>> result.
>> Anyone confirms?
> yes, It is a problem with the last version, until yesterday it worked!
> Tomorrow I have a presentation about WPS and I would like to use WPS
> plugin and this problem is really a blocker for me.
> How can use the qgis master version of yesterday?
Hi Luca, did you ever get this working?
I'm trying with QGIS WPS against Geoserver and having no luck still :(
Not sure if Geoserver or QGIS issue.
Tyler
