[Qgis-developer] Shipping SAGA with QGIS
Victor Olaya volayaf at gmail.com
Sun Feb 24 05:11:05 PST 2013
Phil
Thanks for you help. Unfortunately, I do not use Mac and cannot test
SEXTANTE in Mac.
The psycopg library is used by algorithms connecting with PostGIS, and
I (wrongly) assumed it should be in all computers where QGIS is
installed. I will add some checking to ensure that it is found and, if
not, disable the corresponding algorithms but not the whole SEXTANTE
plugin
Regarding the error you see when executing SAGA, In Mac it is
performing the same check than in Linux, but it seems that it is not
working fine, even if SAGA is actually installed. Making SEXTANTE run
a small test algorithm and check the result sounds like a better
option, which would work for all OS's
Thanks again for your help.
Victor
2013/2/23 Phil Hess <macpgmr at fastermac.net>:
>>>I tried installing SEXTANTE just now on a Mac but it crashed with a missing
> "psycopg2" error message.
>>>This is not a standard Python package on Mac.
> I see now that psycopg2 is also provided as a Mac package here:
> http://www.kyngchaos.com/software/python
> Installing Psycopg2-2.4.5-2.dmg allows the SEXTANTE installation to complete
> successfully.
> However, SEXTANTE doesn't seem to know about my SAGA:
> "It seems that SAGA is not correctly installed in your system.
> Please install it before running SAGA algorithms."
> Thanks.
> -Phil
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Shipping-SAGA-with-QGIS-tp5036274p5036389.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
