[Qgis-developer] New Print Composer UI: Position and Size
Andreas Neumann
a.neumann at carto.net
Wed Feb 27 00:44:50 PST 2013
I used the new print composer UI a bit more and came across a problem,
esp. on Ubuntu:
The "Position and Size" section in the item properties: first there are
the line inputs for x,y,width,height and to the right there is the
choice of the reference points. However, the line inputs of
x,y,width,height are way too wide (they could be a quarter or third of
the size) and one has to scroll to the right to see the choice of the
reference point.
See http://www.carto.net/neumann/temp/print_composer_ui_problem.pdf to
see the problem.
Do you think that his problem can be fixed?
Thank you a lot for your efforts!
Andreas
