[Qgis-developer] New Print Composer UI: Position and Size
Larry Shaffer
larrys at dakotacarto.com
Wed Feb 27 07:45:52 PST 2013
Hi Andreas,
On Wed, Feb 27, 2013 at 1:44 AM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi,
> I used the new print composer UI a bit more and came across a problem,
> esp. on Ubuntu:
> The "Position and Size" section in the item properties: first there are
> the line inputs for x,y,width,height and to the right there is the
> choice of the reference points. However, the line inputs of
> x,y,width,height are way too wide (they could be a quarter or third of
> the size) and one has to scroll to the right to see the choice of the
> reference point.
This is a known issue on all platforms [0]. Essentially, the forms widths
need to be reduced for some of the item property panels, and a reasonable
default width needs set.
I'll be working on it today after I finish an issue with slow composer
duplication. If you see anything else that's a problem with the new
composer GUI, please report it and I'll try to make sure it is addressed.
Regards and thanks,
Larry
[0] http://hub.qgis.org/issues/7194
See http://www.carto.net/neumann/temp/print_composer_ui_problem.pdf to
> see the problem.
> Do you think that his problem can be fixed?
> Thank you a lot for your efforts!
> Andreas
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130227/5dba9353/attachment-0001.html>
