[Qgis-developer] New Print Composer UI: Position and Size
Andreas Neumann
a.neumann at carto.net
Wed Feb 27 08:12:28 PST 2013
Thank you Larry - much appreciated!
Andreas
Am 27.02.2013 16:45, schrieb Larry Shaffer:
> Hi Andreas,
> On Wed, Feb 27, 2013 at 1:44 AM, Andreas Neumann <a.neumann at carto.net>wrote:
>> Hi,
>> I used the new print composer UI a bit more and came across a problem,
>> esp. on Ubuntu:
>> The "Position and Size" section in the item properties: first there are
>> the line inputs for x,y,width,height and to the right there is the
>> choice of the reference points. However, the line inputs of
>> x,y,width,height are way too wide (they could be a quarter or third of
>> the size) and one has to scroll to the right to see the choice of the
>> reference point.
> This is a known issue on all platforms [0]. Essentially, the forms widths
> need to be reduced for some of the item property panels, and a reasonable
> default width needs set.
> I'll be working on it today after I finish an issue with slow composer
> duplication. If you see anything else that's a problem with the new
> composer GUI, please report it and I'll try to make sure it is addressed.
> Regards and thanks,
> Larry
> [0] http://hub.qgis.org/issues/7194
> See http://www.carto.net/neumann/temp/print_composer_ui_problem.pdf to
>> see the problem.
>> Do you think that his problem can be fixed?
>> Thank you a lot for your efforts!
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
