[Qgis-developer] Maptips in QGIS Web Client
Pēteris Brūns
pb at sungis.lv
Wed Feb 27 02:17:33 PST 2013
this is just a clarification not recommendation.
How is with jQuery and Ext mixing or that is unimportant? Some of the
alternatives are jQuery plugins or in relation with jQuery.
Regards,
On 2013.02.27. 12:00, Andreas Neumann wrote:
> Hi all,
> We are looking for a replacement for the current map tips in QGIS web
> client. The ExtJS 3.x tooltips are sort of buggy and limited, the
> OpenLayers popups are not too great either.
> Do you know any flexible (and lightweight) JS or CSS based tooltip
> libraries that you would recommend?
> Necessary features:
> * follows mouse when not clicked
> * dynamic content
> * show/hide
> * click fixes tooltip at a given position - allows user to interactively
> use tooltip content and click - should disable moving tooltips when open
> * different styling - nice defaults
> If you have good examples, example code, experiences or recommendations
> regarding these maptips/tooltips - please let us know.
> Alternatives I found are:
> * ExtJS tooltips - currently used
> * OpenLayers tooltips - Bernhard Ströbl is currently testing them
> * QTIP2: http://craigsworks.com/projects/qtip2/
> * Opentip: http://www.opentip.org/
> * Tipped: http://projects.nickstakenburg.com/tipped
> Can you recommend any of the above?
> Thanks,
> Andreas
> Qgis-developer mailing list
Pēteris Brūns
SunGIS
+371 26336691
pb at sungis.lv
