[Qgis-developer] Maptips in QGIS Web Client
Andreas Neumann
a.neumann at carto.net
Wed Feb 27 02:23:51 PST 2013
ExtJS is our main framework. As the ExtJS 3x tooltips do not meet our
demands we are looking for an alternative.
I believe it should be possible to mix ExtJS and jquery - from what I
learned on Google.
"Tipped" seems to be commercial (licensed per domain) - so we cannot use
that.
Andreas
Am 27.02.2013 11:17, schrieb Pēteris Brūns:
> Hi,
> this is just a clarification not recommendation.
> How is with jQuery and Ext mixing or that is unimportant? Some of the
> alternatives are jQuery plugins or in relation with jQuery.
> Regards,
> On 2013.02.27. 12:00, Andreas Neumann wrote:
>> Hi all,
>> We are looking for a replacement for the current map tips in QGIS web
>> client. The ExtJS 3.x tooltips are sort of buggy and limited, the
>> OpenLayers popups are not too great either.
>> Do you know any flexible (and lightweight) JS or CSS based tooltip
>> libraries that you would recommend?
>> Necessary features:
>> * follows mouse when not clicked
>> * dynamic content
>> * show/hide
>> * click fixes tooltip at a given position - allows user to interactively
>> use tooltip content and click - should disable moving tooltips when open
>> * different styling - nice defaults
>> If you have good examples, example code, experiences or recommendations
>> regarding these maptips/tooltips - please let us know.
>> Alternatives I found are:
>> * ExtJS tooltips - currently used
>> * OpenLayers tooltips - Bernhard Ströbl is currently testing them
>> * QTIP2: http://craigsworks.com/projects/qtip2/
>> * Opentip: http://www.opentip.org/
>> * Tipped: http://projects.nickstakenburg.com/tipped
>> Can you recommend any of the above?
>> Thanks,
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
