[Qgis-developer] Maptips in QGIS Web Client
rldhont
rldhont at gmail.com
Wed Feb 27 02:26:01 PST 2013
Hi Andreas,
I think, you can do what you want to do with OpenLayers Popup, just hack
it ;-)
René-Luc
Le 27/02/2013 11:23, Andreas Neumann a écrit :
> Hi,
> ExtJS is our main framework. As the ExtJS 3x tooltips do not meet our
> demands we are looking for an alternative.
> I believe it should be possible to mix ExtJS and jquery - from what I
> learned on Google.
> "Tipped" seems to be commercial (licensed per domain) - so we cannot use
> that.
> Andreas
> Am 27.02.2013 11:17, schrieb Pēteris Brūns:
>> Hi,
>> this is just a clarification not recommendation.
>> How is with jQuery and Ext mixing or that is unimportant? Some of the
>> alternatives are jQuery plugins or in relation with jQuery.
>> Regards,
>> On 2013.02.27. 12:00, Andreas Neumann wrote:
>>> Hi all,
>>> We are looking for a replacement for the current map tips in QGIS web
>>> client. The ExtJS 3.x tooltips are sort of buggy and limited, the
>>> OpenLayers popups are not too great either.
>>> Do you know any flexible (and lightweight) JS or CSS based tooltip
>>> libraries that you would recommend?
>>> Necessary features:
>>> * follows mouse when not clicked
>>> * dynamic content
>>> * show/hide
>>> * click fixes tooltip at a given position - allows user to interactively
>>> use tooltip content and click - should disable moving tooltips when open
>>> * different styling - nice defaults
>>> If you have good examples, example code, experiences or recommendations
>>> regarding these maptips/tooltips - please let us know.
>>> Alternatives I found are:
>>> * ExtJS tooltips - currently used
>>> * OpenLayers tooltips - Bernhard Ströbl is currently testing them
>>> * QTIP2: http://craigsworks.com/projects/qtip2/
>>> * Opentip: http://www.opentip.org/
>>> * Tipped: http://projects.nickstakenburg.com/tipped
>>> Can you recommend any of the above?
>>> Thanks,
>>> Andreas
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
