[Qgis-developer] Print composer feature request
Andreas Neumann a.neumann at carto.net
Thu Feb 28 08:33:24 PST 2013
 +1 for such a shortcut in the toolbar (with a drop-down menu if there
 are several maps?) or with a right-click context menu.
 I also find the current way of setting the extent quite complicated.
 Andreas
 On Thu, 28 Feb 2013 08:17:06 -0800 (PST), Régis Haubourg wrote:
> Hi All,
> before creating a ticket, I would like to discuss a small new feature
> with
> you.
> Setting a map extent to current MapCanvas extent is not quite simple
> for
> users that want to open a map composer, rezoom it and print. The
> question is
> frequently asked to me.
>  User has to select the map with the select tool first, then find the
> item
> properties tab, then scroll to find the right button in the extent
> collapsible group.
> I'm wondering how we could have some kind of shortcut to 'Set to map
> canvas
> extent' somewhere.
> Could we imagine button in the toolbar next to select and navigate
> tool,
> greyed out if no map object is selected? Any objection to that?
> I was also thinking of starting to enable right clic contextual menu
> on
> objects, but that would need to some more options.
> régis
> http://osgeo-org.1560.n6.nabble.com/Print-composer-feature-request-tp5037542.html
> Sent from the Quantum GIS - Developer mailing list archive at
> Nabble.com.
> Qgis-developer mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
