[Qgis-developer] New OpenStreetMap integration
Martin Dobias
wonder.sk at gmail.com
Thu Feb 28 23:23:58 PST 2013
On Fri, Mar 1, 2013 at 12:03 AM, Borys Jurgiel <lists at borysjurgiel.pl> wrote:
> Dnia czwartek, 28 lutego 2013 o 23:48:48 Martin Dobias napisał(a):
> First, InitSpatialMetadata() doesn't accept any parameters (AFAIK before
> version 3.0.2). After removing the crs string from there the conversion went
> with no errors, but the created db has no geometry columns.
> Here are the osm & db files: http://tmp.borysjurgiel.pl/testosm.tar.gz
Your DB file looks good: it has all the _topological_ tables fully
populated. Now you just need to export data you need (with tags you
need) to SpatiaLite tables.
Martin
