[Qgis-developer] Better options dialogs
Etienne Tourigny
etourigny.dev at gmail.com
Sat Jan 5 08:11:04 PST 2013
On Sat, Jan 5, 2013 at 12:46 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> On Fri, Jan 4, 2013 at 6:52 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
>> Hi Larry
>> On Fri, Jan 4, 2013 at 6:47 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>>> Hi Matthias and Nathan,
>>> I was just about to bring this topic back up myself. :^) Yes, I can
>>> work on this next (probably this weekend). I'll start with the main
>>> app options dialog, cause it's the simplest.
>> Great to hear that ;-)
>> I just wanted to add that I would also appreciate (for options dialog)
>> what Tim has already mentioned: the "advanced" tab with a property
>> list widget (something like [1]): we have lots of settings that are
>> very rarely used (and some of them are even hard to decipher for
>> developers!), so moving such clutter outside of regular tabs would
>> bring some fresh air to the options dialog. Of course this can be done
>> completely separately from what you're going to implement, just wanted
>> to point out that this would a welcome addition, too :-)
>> [1] http://www.myvirtualdisplay.com/wp/wp-content/uploads/2008/11/firefox_config.png
> I have in the past written a simple widget based on QT Settings editor
> example [0].
> It does exactly what you mention.
> I can try to dig up that code, post a screenshot and create a pull
> request for others to review.
> [0] http://doc.qt.digia.com/qt/tools-settingseditor.html
> Etienne
I have pushed this to my branch
https://github.com/etiennesky/Quantum-GIS/tree/settingseditor
Attached is a screenshot - first basic implementation is a standalone
dialog that can be opened in Settings->Settings Editor.
It allows to edit existing settings keys only, but could be modified
to include non-existing keys also.
It needs improvements for non-string keys (such as bool or integer
values with special meanings), because it treats most values as string
and uses only lineedits for changing values.
Cheers
Etienne
>> Regards
>> Martin
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130105/506d983f/attachment-0001.jpg>
