[Qgis-developer] Better options dialogs
    Etienne Tourigny
    etourigny.dev at gmail.com
    Sun Jan  6 13:40:02 PST 2013
On Sat, Jan 5, 2013 at 7:48 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> See my reply inline.
>>> Where do you get the list of properties from? Could tags and descriptive
>>> text be added to these settings?
>> Actually they are read from the settings file / registry by QSettings.
>> So anything not in the user's setting does not show up.
> ok
>> Anything more complex such as you mention would require a csv or xml
>> file with description and tags for each settings key.
>> A csv file would be easier to write and maintain, but an xml file
>> would be easier to parse I guess. Unless someone can point me to
>> a handy xml editor or csv-to-xml tool.
> Ok - we would also need multi-language titles and tags and it should be
> easily translatable. Can we re-use some existing file for that purpose
> and extend it with the tags for the fuzzy search?
Actually looking at the existing code, it's based on QTreeWidget so
any searching functionality would require re-writing it with a
QTreeView and model, a bit more involved.
I have made some adjustments to the code at [1] (to add support for
boll, int and double types), I was wondering if I should make a pull
request or merge it as it is so other devs can have a look?
[1] https://github.com/etiennesky/Quantum-GIS/tree/settingseditor
Cheers,
Etienne
>> Another thing that would be nice would be the possible values that a
>> setting can take, in a dictionnary (key=value pairs) style.
>> (e.g. 0="value1";1="value2")
> yes - it should also be possible to manually add/change settings that
> one could read/write per python script.
> Andreas
> Qgis-developer mailing list
